HMMM
When I start the car it will show like 14 afs and slowly crawl up to"---"
then it wont move...
I know the car is not running lean as I riched the mixture and it puffs black smoke.
Anyone experience this?
If I diconnect it the gauge will read 14.5 when its disconnected.. a soon as I connected.. even if the car is not running.. it will start going up up and until ---
If I need a new one.. does anyone know the part number for the AEM wideband gauge?
Wideband shows (---)
hgallegos915
-hec
- mx-3_4evr
Re: Wideband shows (---)
did you calibrated?
hgallegos915
It is suppossed to come calibrated to the gauge.
Also the 1 year warranty expired this past august
-hec
- marcdh
Do you have it in one of your headers? I think it's meant to be 24"+ away other wise it will fry in a high reving or turbo engine. (mine is in my front header...temporary and no turbo!). Also should be at 10deg incline. Sucks
I would of thought it's the sensor, not the guage broken, which is at least the cheaper bit.
Controller/guage part #:
http://www.aempower.com/ViewCategory.aspx?CategoryID=67
View Worklog
View Worklog
hgallegos915
Thanks! I already ordered the sensor
-hec
