1992 or 1994 BP01
MX3Project2006
1992 or 1994 BP01
Post by MX3Project2006 »
Was wondering if there is any difference in motors when it comes to the yrs. The MX-3 that it will be going into will be a 1992. The reason for this is because I can get either car ( the whole car ) for 350.00 and need to act quick.
Mi|<E
Re: 1992 or 1994 BP01
Post by Mi|<E »
The only thing I can think of that might apply is the 94 could be a long nose crank and the 92 a short nose crank.
Its the size of the crank bolt which fastens the pulley. You want the larger bolt head in this case.
I could be wrong on that, other than that one thing to look for they should be identical.
Unless one is out of a Ford Escort GT. Thats a whole new bag of marbles.
MX3Project2006
Thanks for the reply, No they are both from a Protege. For some stange reason I thought the 94 had VICS.
