100% metal is sure bether than 50% metal, 50%plastic of aftermarket ones.
I got mine only 2 years old and sounds allready ruined.
NEW solution to front Swaybar endlinks found!!!
Re: NEW solution to front Swaybar endlinks found!!!
K8 running LPG (Liquified Petrol Gas)
i'm confused you say they are bolt in like stock but these look only half like the stock ones... did you drill a hole into the front control arm to connect that part of the link up? or was there a hole already there? (i haven't looked closely at my CAs in a while so i can't recall offhand)
ProjectMx
My BP and AWD build thread
Cardomain
93 Mx-3 GS with bp and GTR AWD system
93 Escort GT daily driving
Cardomain
sorry I wasnt clear, there is a predriled hole already there. b/c the 323, protege endlinks bolt through there.projectmx wrote:i'm confused you say they are bolt in like stock but these look only half like the stock ones... did you drill a hole into the front control arm to connect that part of the link up? or was there a hole already there? (i haven't looked closely at my CAs in a while so i can't recall offhand)
- mx3autozam
more info on the spherical bearing links you are selling please!!!wytbishop wrote:I am a little biased, obviously, but the big problem I have with stock replacement, and the reason I decided to build and sell the spherical bearing end links, is that they were nearly impossible to get off. Once they've had a few years to rust and corrode, they are very hard to get off. I also wanted something more rigid.
but for $20 this is a good alternative.
93 Mazda MX3 KLZE Turbo
Very cool and very timely! (I am rebuilding my Suspension currently). So I wonder what 240SX rear end-links look like?
Dominic Toretto's whip is a MaZda and his cell phone number starts in "(323)"
My work log http://mx-3.com/phpBB3/viewtopic.php?f=46&t=72471
This thread contains the information you seek. I will be doing another round in a little while. I have a little too much going on right now.mx3autozam wrote:more info on the spherical bearing links you are selling please!!!wytbishop wrote:I am a little biased, obviously, but the big problem I have with stock replacement, and the reason I decided to build and sell the spherical bearing end links, is that they were nearly impossible to get off. Once they've had a few years to rust and corrode, they are very hard to get off. I also wanted something more rigid.
Better yet:
$6.57 each off Amazon....
http://www.amazon.com/Beck-Arnley-101-4 ... 169&sr=8-2" onclick="window.open(this.href);return false;
'94 GS
