anyone have aftermarket gages
jackal2000
I need some aftermarket gauges cause mine done read properly, I want to convert to a digital setup or anyting for know,but my gauges are reading wrong and its causing me to go slower
zytariuk
Re: anyone have aftermarket gages
The gauges won't 'cause' you go to slower. The gauges needle has probably moved to a different spot because something under the hood is causing you to loose performance...<p>[ June 19, 2003: Message edited by: zytariuk ]</p>
<img src="http://members.rogers.com/zytariuk/images/mx-3.gif" alt=" - " />
1992 Mazda Mx-3 GS - Beige metallic
zytariuk's mx-3 page (updated June 12th, 2003)
