I need it to fit a Probinator chip to my ECU for my KLZE to run properly.
It needs to have a specific number on the actual Chip inside the ECU.
Here is info to check if it is the correct ECU:
I need those numbers. the last 4 digits mainly. If it starts with a 16** it CANNOT be chipped. Example would be in the picture that one cannot be chipped.If it starts with like a 2*** it CAN be chipped.
![Image](http://memimage.cardomain.com/member_images/8/web/728000-728999/728690_24_full.jpg)
k8 ecu questions.
Alot of people swap in the KLZE motors into the mx-3. Something to remember is, not all k8 ecus can be chipped. Only certain ones can. What I need to know is the eprom number inside your ecu. In the picture here is where the chip is at.
First take off the 4 phillips screws on top. Then there are like 4 or 5 more holding part of the ecu in. Take out those, and then flip up the board and look for the eprom with a sticker I circled it in red in the picture below. I need those numbers. the last 4 digits mainly. If it starts with a 16** it CANNOT be chipped. Example would be in the picture that one cannot be chipped. If it starts with like a 2*** it CAN be chipped.
I am based in the UK.
