Welding?
- slimmyslim1420
Welding?
What is the smallest possible welder that you can use to effectivly and efficiently weld exhaust parts? As in amps, gas, or no gas, mig, tig, flux? Any help is appreciated.
1992 GS ZE swap 94 dash swap drilled and slotted rotors full ceramic pads CS SS clutch and brake lines KL-36 ecu zx-2 tokico struts eibach springs short shifter Tenzo exhaust Hi flow cat 2.5 in piping
Re: Welding?
I used an arc welder set at 75 amps and it worked fine. Usually for jobs like that 75 amps if perfect as exhaust pipes are father thin by comparison to other weld. You can do the flanges with a 75 amp well. Bonus is the welders a cheap to buy.
- mitmaks
Re: Welding?
I have 140 MIG gas, it will weld pretty much anything I need up to 1/4 inch thick I think.
Re: Welding?
I might be thinking of doing this
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
Re: Welding?
As you asked what the smallest would be I responded to that. Here's mitmaks welder. http://reviews.canadiantire.ca/9045/058 ... eviews.htm" onclick="window.open(this.href);return false; http://www.canadiantire.ca/browse/produ ... 4396672983" onclick="window.open(this.href);return false;
Probably comes on sale for around $499
- mitmaks
Re: Welding?
here's one like Ive got http://cgi.ebay.com/Weldmark-140-MIG-We ... dZViewItem" onclick="window.open(this.href);return false;
One of the best welders (quality wise) made my Hobart who's known for best welders. I spent another $120-$150 on a bottle (filled up) or you can rent one. Best thing is to buy one so that way you take it back just to refill and you always have it when you need it.
