![Image](http://img32.picoodle.com/img/img32/4/7/22/f_bm_908cc2b.jpg)
put a breather filter or not?
- Tropical Emerald 1993
I was thinking about the first option. Any positive experiences with breather?
Re: put a breather filter or not?
I googled this but couldn't get any good info, I'm curious about this since I want to do it too, more for the sound than for anything. I don't understand the purpose, since the air is filtered already.
1994 Mazda MX3 RS | Rebuilt B6DE | Stock
- onlytrueromeo
2 no, 1 yes.
i agree on the 2 no 1 yes i personally left the pvc valve but removed the hose going from the valve cover to the intake tube mainly to help keep the TB clean i just put a vacume cap on the intake side and im am very happy with the results i nolonger have to worry about the TB cetting gunked up a standard 12 mm breather works fine
i left the pvc valve on for the fact that it aids greatly in sucking all the crank case gasses other than stewing up and festering as i like to call it good luck -johnny
LIFE IS A SEXUALLY TRANSMITED, TERMINAL, DESIESE. AND WE ALL SUFFER FROM IT.
http://en.wikipedia.org/wiki/PCV_valve" onclick="window.open(this.href);return false;
If you put a breather on the crank case inlet and leave the PCV valve connected to the intake - it will create a vacuum leak situation. If your engine is old and if there's a lot of blowby gases present - then the "leaked" air picks up its own "fuel" and you wont feel much of a difference. If you dont have much blowby gases then it will definitely mess with AFR - especially at idle.
If oil is being pushed through crank case inlet tube - then the PCV system is not functioning properly (most likely blocked PCV valve).
![Image](http://img517.imageshack.us/img517/5927/fliegetn0ss7.gif)
I put on a breather filter on my B6 DE....
... It looks neat.
... It looks neat.
- hotsiit
I put a breather on choice number 1 on my SOHC-turbo...and it makes an oily mess under-hood
That will be fixed once the new motor goes in![Very Happy :D](./images/smilies/icon_biggrin.gif)
1993 Mazda MX-3 RS-Turbo
1993 Mazda RX-7 touring
1983 Mazda RX-7 GSL
1987 Jeep Comanche
![Image](http://i603.photobucket.com/albums/tt118/hotsiit/mx3-into-1-1.jpg?t=1242927937)
1983 Mazda RX-7 GSL
1987 Jeep Comanche
so in REALITY does the engine idle better or have less emissions?
It looks neat.
You can do a filter, but a breather may be illegal. They're not allowed in Ontario at least to vent that to atmosphere, otherwise it's a nice fine.
