EGR valve
blaudust7
EGR valve
Post by blaudust7 »
Where is the location of the egr? My Chiltons manual is showing the location across from the battery in front of the brake master cylinder. Is this correct, and can I use an egr off the 2.5L V6?
hgallegos915
Re: EGR valve
Post by hgallegos915 »
on the rear head
-hec
Dragyn Vyrus
Re: EGR valve
Post by Dragyn Vyrus »
there you go man
not sure if you can use the egr off the 2.5 though...
93 MX-3 ZE-GS - Sold
95 MX-3 RS - Bone stock winter car.
92 JDM turbo MR2 - SSQV, Cusco strut tower bar, ATS intercooler kit, Berk Exhuast, HKS EVC-S
msd-supermx3
Re: EGR valve
Post by msd-supermx3 »
lol i know this might sound funny but i took mine off and pluged the wholes...
Steve_SK
Re: EGR valve
Post by Steve_SK »
I had error code no. 16, which is EGR system error. So I removed my EGR valve, checked solenoids, vacuum hoses, cleaned EGR valve in naphtha (pic in my worklog), bought a new EGR gasket and installed it back. It works perfectly now, engine is back in great condition in 1500-4000 rpm. I would not recommend blinding the EGR.
MX-3 V6 1993 | Black | EU-spec | K819
hgallegos915
Re: EGR valve
Why not? its just for emissions :/
just block it out and have it connected to get rid of the code. No negative reactions are done.
-hec
Steve_SK
Re: EGR valve
Post by Steve_SK »
It reduces combustion temperature in preset area of rpm, improves idling, reduces NOx and exhaust smoke etc. There are many discussions and articles about EGR system on the internet.
shameem
Re: EGR valve
Post by shameem »
Steve_SK wrote:reduces combustion temperature ... improves idling .... reduces NOx ....exhaust smoke ....
That sounds like an EGR commercial ;)
EGR system is not used during idle-
http://en.wikipedia.org/wiki/Exhaust_gas_recirculation" onclick="window.open(this.href);return false;
Steve_SK
Re: EGR valve
Post by Steve_SK »
Yes, but when the valve is stuck and still open during idle, then idling is not smooth.
I do not say "don't blind EGR". I just say, clean it and use it, I recommend it, but it is every MX3 owner's decision - keep or remove. :)
colinsmx3
Re: EGR valve
Post by colinsmx3 »
You can not use the EGR from the 2.5 since it's a totally different part number and is about $200 more then the 1.8 for some reason! :shrug: I looked it up at work here.
Re: EGR valve
Post by wytbishop »
hgallegos915 wrote:Why not? its just for emissions :/
It reduces your impact on the planet. It's the least you can do.
