speed in 5th gear, 3000rpm
Tropical Emerald 1993
Post by Tropical Emerald 1993 »
ok I know my car leaks oil so I'm curious how bad is it. I get nearly 100km/h :?:
Re: speed in 5th gear, 3000rpm
it's 88hp, sohc :wink:
mortenmorfar
Post by mortenmorfar »
sounds about right, im at 140Km/h @ 4400rpm+- in by Dohc
Ryan
Post by Ryan »
Do a fifth gear swap if you're concerned, or want a higher top speed... not sure if its smart to go much faster than 190 though. Theres lotta info on here.
@4000rpm goes around 130km/h but the engine is louder and I dont think it would last long if I drive it like that on mororway. I need the car for a few more years :P
mortenmorfar
ehm if it's leaking oil you should have it fixed.
if the engine is in good shape, it shouldn't have any problems with driving 4000rpm for hours, as long as there is oil and cool water it should be fine.
bfamiluyi
Post by bfamiluyi »
mortenmorfar wrote:sounds about right, im at 140Km/h @ 4400rpm+- in by Dohc
lol. at 4000 rpm my car run at a speed of 90+ mph LOL and it's a sohc engine
FASTLANE ONLY
1993 mazda mx3 1.6 sohc K&N INTAKE R1 MUFFLER SOON TO BOOST (SOHC TURBO)
1989 nissan 240sx sr20 wreck RIP
2002 saturn Ls2 RIP
Ryan
Post by Ryan »
The have exactly the same gear ratios, because they have exactly hte same transmission..... DOHC and SOHC
mortenmorfar
Okay maybe it's "only" 4000rpm @ 140Km/h, I don't really remember
But I don't get what an oil leak have to do with the transmission ? you could still do 180Km/h with a car that's leaking oil
it has nothing to do with the speed the car is traveling at xxxx rpm
leaking oil=bad headgasket=bad compression
so it is a bit slower but not that much.
@4000prm engine is louder than other cars, I feel like killing it :confused2:
mortenmorfar
Yes the engine is a bit loud compared to normal "family" cars, but it's supposed to be a "sports" car, just drive it belowe 3000rpm then it's quiet :P
but if the headgasket is damaged don't drive the car or you could ruin the whole engine
