KLZE distributer on my K8 ????
- punkindrublic
can i use the distributer off my klze for my K8 ??
i fried my 1.8L V6 distributer !!!
any help would be great !!
i have a str8 neck ZE pulled from a probe !!!!!!
thanks For the Help
thanks For the Help
1995 MX-3 GS (black) stock engine... for now hehe...
MSfront... mssides... GS wing...
5" tach w/shift light... A/F, Volt, & Oil Pressure gauges in dash vents... front and rear strut braces....
WORK IN PROGRESS
WORK IN PROGRESS
- punkindrublic
Re: KLZE distributer on my K8 ????
i just found the other post
HOW TO... klze disty on a k8
wow im slow !!
wow im slow !!
WORK IN PROGRESS
WORK IN PROGRESS
- punkindrublic
is that the only way to utilize a klze disty on my K8 ?
the thing is i have a ZE in my garage with the Hei Mod wires... but no ext coil !!!!
i just dont want to spend 300 on a used disty for my K8 !!!!!! which is currently in my mx...
any suggestions ????!!!!!!!!!!!!
WORK IN PROGRESS
WORK IN PROGRESS
The ZE distributor is nothing more than a cap and a rotor so you must use an external coil.
- fowljesse
The metal part is exactly the same, except no coil?
Just in case you decide to buy a Disty, here's a link to a seller.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0213059694" onclick="window.open(this.href);return false;
I would suggest you sell me the ZE disty then go to Norhtern Performance on Parkdale ave and get another disty from them. Just a suggestion.
The only thing in the metal portion of the ZE disty is the cam angle sensor. No coil and no ignitor.fowljesse wrote:The metal part is exactly the same, except no coil?
- punkindrublic
so my only shot is the hei mod !!??
WORK IN PROGRESS
WORK IN PROGRESS
The stock ZE in it's native chassis uses an external coil and igniter. Usually from what I've seen the coil and igniter are not sold with the ZE engines that are imported. I imagine it is possible to get them and use them, but they would not be easy to find.
The HEI mod is extremely easy and can be done for <$50.
Not to steal the thread but would a 1993 K8 disty work on a 1993 KLZE?
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
- FlyVFR
It depends on the wiring harness. If using a 93 MX-3 GS car harness, then I would say yes.Juans_93_MX3 wrote:Not to steal the thread but would a 1993 K8 disty work on a 1993 KLZE?
Stock 92 MX-3 GS
93 MX-3 GS KLZE
98 BMW 328IS
81 Trans AM NASCAR Pace Car
80 Trans Am INDY Pace Car
www.MyMX3.com Domain For Sale!
My Feedback File
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
You can use whatever disty came with the car originally.
I have what I believe to be a 93ish ZE and I have my 96 Disty on it.
