Actually changing the gears isn't that bad either. I had mine apart this morning actually! You take off the black steel cover on the tail of the transmission, and there they are! Then take an inch and a quarter socket to take off the retaining nuts (after you unstake them of course
) You will now need to take a punch and tap out the pin stock holding the selector fork in place, and slide the gears and synchros right off. I didn't have all the parts I needed to finish my swap so I had to put my ground to nothing 5th gears back in, when I do it for good I'll take some really nice pics and do a step by step how to! It will be for putting G-series 5th gears in an F-series trans, but its the same basic principle. I am using some Zx2 gears in mine because they have super overdrive 5th gear.
Oh and the final drive ratio is constant throughout the whole system, but you change the input RPM's when you shift through the gears, so no a different 5th gear will not change the final drive ratio in the differential ring and pinion, but it will change the input RPM's and the output RPM's, and WILL make a world of a difference if you change the gears with a drastically different 5th gear setup.
