Installed kl36 ecu. Rad fan always on??
hgallegos915
Re: Installed kl36 ecu. Rad fan always on??
Post by hgallegos915 »
can someone post a pic of the diagram for the cel?
Mine lost the cap . i know by memory which ones are ten and ground but I dont know which one is fen.
-hec
94mx3precidia
Post by 94mx3precidia »
shameem wrote: The led goes between FEN and B+ and the jumper goes between TEN and GND.
are you sure about this? i dont really want to be sticking wires and pins into random places to see what happens.
Have you just read about it or have you actually done it yourself?
1994 MX-3 GS KLZE, Probinator, Bully stage 1 (probe GT), B&M Short Shifter, 2 1/4" Custom headders back.
shameem
Post by shameem »
I have done it myself - its like a replacement for CEL ..... But it was on a stock 94 4 cyl - i dont know if it will work for your engine/ecu combo
94mx3precidia
well i tried the FEN and +b with ten and gnd and no go. the led didnt even light up. i guess the only way i can get codes is if i switch the ecu's and go for a drive.
