Clogged CAT?
- fighttillyoudie0
- umcamara
Re: Clogged CAT?
When was the last time it used the litter box?
That was dumb...
That was dumb...
Re: Clogged CAT?
LMFAO!!!
Tard!
Tard!
93 MX-3 2.5 KLZE - KL101 \\ H&R Springs \\ Short Shifter \\ 17" ADR Rims \\ 205/40/R17 Namkang Tires \\ Millenia Manifold \\ Rockford Amp \\ Rockford 12" Sub \\
--- K8 was my gateway drug.
- mitmaks
Re: Clogged CAT?
rotten egg smell, reduced performance, bad acceleration/sputtering.
- fowljesse
Re: Clogged CAT?
It's easy to take it off (with some penetrating oil). Look at the sun through it. I hollowed mine out, and passed emissions.
Re: Clogged CAT?
if you replace your Cat do not let the muffler shop keep it! over the years your cat builds up deposits, deposits of what you might ask, well Platinum. You can make a lot of money selling Used catalytic converters to places that melt them down for the platinum deposits, a used catalytic converter can go for up to 200 dollars.
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
Re: Clogged CAT?
I believe that a muffler shop will just use an outside temperature reader tosee if the temperature is consistent... if it's overly high on the cat then it's probably clogged... somebody correct me if I'm wrong...
- 94mx3precidia
Re: Clogged CAT?
this is true, there was a big operation at my work and all they did was just collect used cats.Mnemonic wrote:a used catalytic convert can go for up to 200 dollars.
1994 MX-3 GS KLZE, Probinator, Bully stage 1 (probe GT), B&M Short Shifter, 2 1/4" Custom headders back.
Re: Clogged CAT?
whats really sad is your typical import car cat gets about 1.9grams of over its lifetime, thats about 1200 dollars
- xxwhiteboyjim22xx
Re: Clogged CAT?
I guess this is one way to cheak it. Entertaining to. lol
http://youtube.com/watch?v=IzyvL5tQLzU" onclick="window.open(this.href);return false;
- fowljesse
Re: Clogged CAT?
Shoot. Mine was really clogged, and I threw away the junk. Thanks for this info! I wondered why the meth freaks are stealing them.
- fighttillyoudie0
Re: Clogged CAT?
So, To get the bolts off; I need penatrating oil? I tried WD-40 But the bolts wouldn't break for me... I don't have any money to spend right now, so I was wondering If a gutted CAT( Someone told me that's Bad to GUT one) would work better than clogged?
- umcamara
Re: Clogged CAT?
You need to soak the bolts for quite some time with the WD-40, or whatever you're using. An impact gun will come in very handy, but you have to try not to strip the bolts, then it becomes a real pain.
IMO, the best method would be:
1) Soak bolts for some time (a day wouldn't hurt, re-applying a couple of times)
2) Heat up really well with a torch
3) Remove with impact gun
Re: Clogged CAT?
There is this stuff that is called PB Blaster. Works wonders on rusted nuts. (that's what she said)
but seriously its good stuff. should be able to get it at any auto parts store or even walmart
1992 Mx-3 GS. ATX to MTX swap. Integra short throw shifter, and CAI. HEI mod. Accell Canister. 3A racing muffler. Straight pipe.
Re: Clogged CAT?
run the car for a little while, jack it up, grab the long handle breaker bar, it'll pop loose
let it cool then go with a regular ratchet
