i got my rs-t out last week , it drives like a charm.i have such crappy street tires, i'll run some half used drag radial on 14inch rims
i changed the whole setup during winter, i swaped my gt-x turbo kit for a more...agressive setting
it<s not the best, dont be rude, i do love her a bit too much
i used a ETDracing manifold,with an external wastegate flange, since the T3 is wastegate-less
installed the tial wastegate with a 1 bar spring, but fuel pressure issues stop me from getting above 11psi(what the megasquirt reads anyways)
i have the sincere impresion that it pulls WAY harder than my vj20, even if it was at 15psi from 3 to 5.5k rpm
the new turbo is giving me about nothing lower than 4k rpm, but when it launch, the powerband is so much smooter yet so much more powerfull
last october i hit 13.78 at 107 on 14'' tires.on bone stock gtx engine(ms management and IC for only mod)
i wish to do about the same time with the new setup, the mid 13 at 10 psi would be great news for me;tell me what you think, i'm so eager to go back to the trac
going to the trac this friday,new setup,what's ure bet?
96 rs-t mx-3, 12.62@114
u have the Zoom Zoom feeling?
Re: going to the trac this friday,new setup,what's ure bet?
i'll try to post my time just to see if ppl will care a little
i had pretty hard time launching the car with the new clutch, but it gave the result i expected
60' 2.2
1/8 9.1
1/4 13.88
104mph
idid basicaly the same time as last year, with 5psi less:P
i snapped a cv axel at my 5th run, so, no improvement for me this week
60' 2.2
1/8 9.1
1/4 13.88
104mph
- XxantwawnxX
awesome job! ew ive never snapped an axel before...must suck
grease everywhere under the engine, one hell of a job
i can shift all of my gear exept the second one.
tranny+cv next week end:/
- XxantwawnxX
at least u did not bend a rod like me.....check pic/vids section : (
- Limegreen mx-3
wth i always blow diff on the line wish i snap axles cheaper to replace.. LOL
13.8 BP-t not bad at all
NICE
NICE
gear 1-3-4-5-r are going like a charm, unfortunatly i think i ruined my second gear, i'll post the vid tomorow, i was trying to act tough in front of a 60'mach1(doing consistend 12 when missing his third gear)
tranny+cv axcel swap next weekend(under waranty:P)
