KLDE swap clutch question.
ok so im about to buy a wrecked probe gt with a rebuild motor and automatic trans. Im going to sell the trans and part out the probe and then swap the motor over to my mx3. My question is when i swap the trans over what flywheel would i use? i hear people using the mx3 gs flywheel on klde/klze because of the weight. does the mx3 flywheel fit with a aftermarket probe gt clutch or do you have to use a different flywheel. Im guessing it will but i wanna make sure befor anything gets purchased.
Thanks
Travis
Thanks
Travis
92 Blaze Red MAZDA Mx3 <GS> ZE, millenia manifold. gutted interior, filled mounts, fidanza fw, act 6puck.
- solo_ryder
Re: KLDE swap clutch question.
mx3 flywheel will work fine, same as a PGT one but weighs less. Get that buckled to a probe clutch and your good
k thanks solo. that what i was looking for.
k now i have another question. does anyone have a good recomendation on some good clutches that will take a good 5-9 psi without slipping? im leaning towards a SPEC stage 3 or 3+, SOuth bend, and Clutchmasters stage 3. i searched on here and probetalk but only really found out that i definetly shouldnt get a ebay clutch which is not one of my options. lol
Thanks
Travis
Thanks
Travis
- solo_ryder
Hey Travis,
It looks like you are on track with the clutches you should be considering. They are all good clutches from what I have heard over the years. I dont know many mx3 guys running spec clutches (I think atlantamx3 runs one) but I know they are good in other vehicles. The clutchmasters are used alot and are good, as are the southbend ones, so either option is great. As for holding power, yea you want at least a stage 2-3 if you are boosting IMO
Good luck
Good luck
- marcdh
I bought a spec stage III, as I have strong urges to boost...haven't got it yet though! No complaints on probetalk on spec, so I just went for it, don't seem to be made out as harsh on trannys as ACT.
View Worklog
View Worklog
Dont go for excedy organic when boosting btw or ebay clutches.. all of those begin to slip at 5 psi of boost lol
i made that mistake and I have to pay for it now.
-hec
- solo_ryder
Hows the pedal feel on that clutch? heavy or light? How does it engage? I know spec clutches are very good and I am considering one for my next clutchmarcdh wrote:I bought a spec stage III, as I have strong urges to boost...haven't got it yet though! No complaints on probetalk on spec, so I just went for it, don't seem to be made out as harsh on trannys as ACT.
- marcdh
Will let you know when I get it, and get it in It's probably in UK customs getting its value doubled I'm predicting a significantly heavier feel compared to clutchmasters or of course OEM, but still daily drivable...I hope!marcdh wrote:haven't got it yet though!
View Worklog
View Worklog
Funny, I use to street race back in the days of North American Muscle cars (340 Dart Swinger)and I use to bring my Borg and Beck racing clutch in to a Brake and Clutch shop. They installed stronger springs, magnafluxed the pressure plate and did the disk over for a fraction of the cost of new. Has anyone looked at getting their stock clutch rebuilt?
- marcdh
My locals charge about $5/600 to rebuild as you just said... needless to say I bought a new one
View Worklog
View Worklog
