wiring harness diagram
cricketol2
been looking and was wondering if any one had found it before, and if do could you please share the wealth thanks
nerd racing
Re: wiring harness diagram
There is a link to an online library data base in the aspire forums, they have pretty much every year make and model's info in there. Do you want a link to the thread? You don't need to be a member to access it.
http://www.mx-3.com/manuals/index.php" onclick="window.open(this.href);return false;
cricketol2
a sohc and a dohc air flow senser are different.. can any one help me with the rewire the sohc has 6 wires and the dohc has 5 wires and the http://www.mx-3.com/manuals/" onclick="window.open(this.href);return false; only shows the colors and not what they do and the sohc is not even there for rewire info
cricketol2
p.s. the 1990-1993 chilton's repair manual is not for a sohc it is for a dohc v6
Its not as simple as rewiring - the electronic principle is different. The SOHC uses a spring loaded vane that moves with the airflow to measure air. The DOHC has a heater element in the airflow path and measures the amount of heat removed from that element as an indication of airflow. You cannot just interchange them without changing all the electronics that go with them (which is built into the ECU).
cricketol2
then would there ba a way to bipas it or to increase the airflow at all
You can either swap a MAF from rx-7 or you can get a standalone EMS with a MAP sensor.....
cricketol2
i found a thing on ebay and i asked how to hook it up and this is what they sent me
Unit installs on vehicles IAT sensor via a single wire splice
will it work with the SOHC i dont think it will just want a second opinion thanks
cricketol2
and what year rx-7 would work , and by standalone EMS with a MAP sensor do you meen a after market or send it to a place like jetsshameem wrote:You can either swap a MAF from rx-7 or you can get a standalone EMS with a MAP sensor.....
