ok, I think I am right that the fuel pump relay is located in the passenger side kick panel bolted to the same bracket that the ecu is attached to.
is that right?
thanks
7
edit:
does anyone know the wiring layout of that relay? it would save me some time when I am setting up my MSnS towmorrow.
I need to know which wire has voltage when cranking and running.
fuel pump relay.
- se7en
fuel pump relay.
1992 mx-3 GS-T, 10-12psi, T3/t4 hybrid, Turbosmart WG, AFPR, SSAC TURBO pipes, MSD Blaster coil, K&N, AEM W/B, MSnS(full standalone), 225Whp street tuned(10psi), 245Whp (12psi)(300bhp!!!)
1992 Fairlady Z(JDM RHD) 2+2 TT black(done!)700whp+
Don't Click Here! Trust me,Time waster!
OldMan
Re: fuel pump relay.
It is on mine, even though mine is a 4 banger. It's simple to check , just unplug it and turn on the key and see if you can hear your fuel pump kick in or not. Hope this helps.
OldMan
OldMan
- umcamara
Not to be an anus, but the ecu's under the center console, not the kick panel.se7en wrote:ok, I think I am right that the fuel pump relay is located in the passenger side kick panel bolted to the same bracket that the ecu is attached to.
