Does anyone have Probinators address, I need chips
Can someone give me Probinators address so I can order from him. Thanks
- Kirk95gs
Re: Does anyone have Probinators address, I need chips
Ryan Dehoyos (probegtze@hotmail.com" onclick="window.open(this.href);return false;)
Thanks. I heard his chip was the one to use?
- Kirk95gs
Thats a big 10-4 Bandit, No smokies are gonna catcha now!
Yes.. thats what I'm getting. He is out of stock on the curved neck eproms but should have some in two days or so.
Kris
Kris
I still recommend NOT getting this chip, even guys that have used the probinator chips have stated that the engines seem to run better using the OEM ecus. Though for the cost of a kl31/36 ecu you could get a megasquirt setup if you feel comfortable with building it yourself which really isn't that hard to do honestly
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
- Kirk95gs
What other issues came up Mnemonic? From what I understand the only real improvment is the VRIS points are spot for the curved. Not to many people need the speed limiter removed but its is a plus I guess. Not trying to be ignerent but I have not found to many people who did not like his chips. I thought it was the next best thing befor going standalone for a curved neck ze. Any info would be appreiciated.Mnemonic wrote:I still recommend NOT getting this chip, even guys that have used the probinator chips have stated that the engines seem to run better using the OEM ecus. Though for the cost of a kl31/36 ecu you could get a megasquirt setup if you feel comfortable with building it yourself which really isn't that hard to do honestly
well im on my phone so I can't go to into it. but I've herd about better idle and fuel economy using oem I believe even hector stated he saw an improvement in how his ran when he went with the klze ecu. as for the rev limiter I can't say I ever had problems with it as it didn't activate till after 7500 rpms and all k series power band ends at 6800 rpm unless heavily modded
you def get better fuel economy and you gain like .1 at the track (depending on driver)
I like my kl36 ecu. Ill probably just use some msd window switches for the vris.
Good thing about the probinator is that you can check codes the regular way.
ALso I think he can set vris points to however u want.
-hec
- Kirk95gs
That was my understanding. I was going to do the MSD switches with my kl36, but I wanted to have the CEL for easy of diagnostics if something came up.hgallegos915 wrote:you def get better fuel economy and you gain like .1 at the track (depending on driver)
i'v done kl36 for a year and a half or so, but then tried probinator and havn't looked back. vris points being spot on has improved overall performance feel (i'v actually done dyno's b4 and after, and w/ the kl36, the power actually dips before vris kicks in, whereas with probinator it remains strong the whole way)
not only that, but i get about 20km/tank further with the probinator
maybe the people who'v had problems messed up the install
AKA Deimos
Chips and pie, pie and chips.
I have probinator too, seems fine to me. Smith18 also has one, works good.
For the price? Can't beat it.
- se7en
I hear chips and vinegar is the way to go.
lol.
Go MSnS, and never look back guys!
You will have to do it anyway when you go turbo...I love it.
lol.
1992 mx-3 GS-T, 10-12psi, T3/t4 hybrid, Turbosmart WG, AFPR, SSAC TURBO pipes, MSD Blaster coil, K&N, AEM W/B, MSnS(full standalone), 225Whp street tuned(10psi), 245Whp (12psi)(300bhp!!!)
1992 Fairlady Z(JDM RHD) 2+2 TT black(done!)700whp+
Don't Click Here! Trust me,Time waster!
