Here's a link to the pics of the clutch job. the shaft that the throwout bearing rides on is all chewed up by the old one flying apart. one of the flywheel pins came out to do I need to worry about that?
http://www1.snapfish.com/thumbnailshare ... _=18925656" onclick="window.open(this.href);return false;
Is my tranny toast or is thi ok? pics
92 MX-3 GS 1.8, looking for ZE.
Re: Is my tranny toast or is thi ok? pics
Any ideas on where to get a used case for cheap?
is anyone having trouble viewing the pics? I think all you have to do when you click the link is click the view now button let me know if it isn't working....
I was considering building the aluminum back up with JB weld and sanding it till the throowout bearing slides smoothly back and forth again any comments or suggestions?
I wen ahead and replaced the flywheel with a brand new one only 42 dollars at napa....
