96 626 tranny possible?
Is it possible to put a 1996 626 tranny in a 1992 mx-3 v6? The 626 is a 4 cylinder. If so what would I need from the 626?? Oh yeah both are automatics. My tranny went out today and I found this tranny from the 626 with 70,000 for 100 dollars. The guy has the whole car to besides the engine so. Please tell me good news. I searched the site but couldn't find info...
- se7en
Re: 96 626 tranny possible?
nah, sorry dude. it won't work.
you need a mx-3 auto from a v6 car.
(computers don't work together otherwise.)
sorry for the bad news.
just convert to manual.(I did)
mx-3 automatics are junk just so you know, I read somewhere that they are made from spun sugar. and I believe it. Mine blew up( lost overdrive and third gear, and all round drove like a bad of shiz.)
7
7
1992 mx-3 GS-T, 10-12psi, T3/t4 hybrid, Turbosmart WG, AFPR, SSAC TURBO pipes, MSD Blaster coil, K&N, AEM W/B, MSnS(full standalone), 225Whp street tuned(10psi), 245Whp (12psi)(300bhp!!!)
1992 Fairlady Z(JDM RHD) 2+2 TT black(done!)700whp+
Don't Click Here! Trust me,Time waster!
can I swap the computers and maybe change the bellhousing to make it bolt up?? This is the only tranny I can find... ANYWAY POSSIBLE??
- se7en
nah man, everyone wonders that.
most automatic mx-3's loose their tranny's.
the ecu is built into the engine ecu, so youi can't swap them.
7
7
For automatic transmissions only -
The 4 cyl and 6 cyl mx3 have the same tranny code and they are pretty much the same (see online manual page TD-019) - that means you can swap between I4 and V6 trannies - you will have to change the bellhousing and possibly speedo gears.....
Find out the tranny code for 626 -
Now if the 626 tranny is the same code as mx3 4cyl then you can atleast attempt this swap.....
- se7en
hmm, i don't think this will work.
but if you want to waste some time, go ahead
I think I read somewhere that the internals a pretty much the same so maybe I could swap the internals for a semi rebuild. I just don't have very much money right now.
- se7en
hmm. well, that maybe a good idea....you may as well try. what have you got to lose.
I wouldn't be surprised if they didn't, I could of sworn that one of the problems is that the ATX doesn't actually fit in our engine bays, it's too big, but i may be wrong.
