I have a curved neck KLZE that I plan to put in my 93 mx3. I'll probably be adding headers and a CAI but will be using a somewhat restricted (compared to ricer bombs) muffler because I want to keep the car as quiet as possible without sacrificing too much power. The stock ECU that's in my car now has the wrong EPROM for chipping, so I'm on the hunt for an ECU. There is a KL-36 ECU on eBay for $200 but I'm not sure if that's all I need.
My questions are, if I buy a KL-36 ECU off eBay, is it simply plug-and-play into my MX3? Would I still need it modified to reflect the slight change in air-flow and/or are there any other changes I would have to make to the ECU or wiring harness and plugs? I mean....is it THE ECU for that engine, or is it for a DE engine and I'll still need it chipped by Probinator??
Also...can someone suggest a good fitting muffler that will allow better-than-stock flow while keeping things fairly quiet? I'll likely be using 2.5" piping btw.
Thanks
