Tricking stock ECU
- se7en
Tricking stock ECU
Can anyone think of a way of tricking the stock ECU into not adding extra timing?
or taking timing out?
can I hack into the knock sensor to trick the ecu into retarding the timing?
cheers
7
cheers
7
1992 mx-3 GS-T, 10-12psi, T3/t4 hybrid, Turbosmart WG, AFPR, SSAC TURBO pipes, MSD Blaster coil, K&N, AEM W/B, MSnS(full standalone), 225Whp street tuned(10psi), 245Whp (12psi)(300bhp!!!)
1992 Fairlady Z(JDM RHD) 2+2 TT black(done!)700whp+
Don't Click Here! Trust me,Time waster!
Re: Tricking stock ECU
I heard some one doing this with an ecu for a tiburon. Might wanna search that.
<a href="http://www.fodey.com/generators/animate ... .asp"><img src="http://r3.fodey.com/117ef9486659942269d ... 7601.1.gif" border=0 width="404" height="110" alt="Ninja!"></a>
- mx3autozam
- se7en
I already unplugged it....
the reason is:
I am tricking the computer to add fuel by adding resistance to the CLT sensor to make the engine think it has to warm up(add more fuel)
unfortunately, it also adds timing.
I was thinking that I could simulate the knock sensor, and trick the ecu into removing timing under boost.....
any thought on this John?
7
the reason is:
7
- RS_OBD'oh_2
you might be looking at a piggy back. I know it's a four letter word here, but it's also your answer. At the very least, I'd just check out it. (AEM Fuel / Ignition controller)
- Custommx3
- Site Administrator
Do not unplug your knock sensor. Engine knock = bad!
- se7en
I didn't, the knock sensor is bad though ![Sad :(](./images/smilies/icon_sad.gif)
Well, i would stop messing with the CLT and do what real tuners do - mess with the O2 sensor values directly to change AFR. I think i recommended O2 clamp to somebody before - you can probably look it up.....
If you do want to manage timing manually without engine management - look into MSD modules -
http://www.msdignition.com/tc_2.htm" onclick="window.open(this.href);return false;
Of course you will need an MSD ignition for that to work.
Megasquirt might work out to be a better option.....
![Image](http://img517.imageshack.us/img517/5927/fliegetn0ss7.gif)
- se7en
ya, I am thinking that megasquirt will be the way to go ![Smile :)](./images/smilies/icon_smile.gif)
sounds like it will be the easiest way lol.
7
7
MAP ECU2 piggy back. I have already been in contact with them and a company that makes patch harnesses for them. I have the wiring diagrams for the 93 ECU which I could sent to you. Not sure on the differences in the pinout from 92 to 93.(EDIT: you could not use the same diagram as I have because I am not boosted yet, but they did the diagrams for me and I'm sure they would do the same for you.) The MAP ECU2 will cost you about $900 and the patch harness is something like $130. IT controls fuel and timing and has outputs for other functions like boost control etc.
I plan on doing most of the things you're doing and when I researched the MSnS it just seemed really tricky. Thats why I started looking for a good piggyback. I think this one is the best. They tell me they have had good success with Miata's on boost and the technology on that car is very similar to ours.
http://www.mapecu.com/map2.html" onclick="window.open(this.href);return false;
I'm not sure why everyone is so down on the piggyback around here. I have one on my bike and it's awesome. I can add or remove fuel at any rpm in 2 minutes.
