oh oh.....funny knocking sound..
- se7en
okay, after some hard driving, at idle, I hear a NON-rythmic tappy/knocking type of sound.... doesn't sound like any Rod knock that I have every heard, but what do you all think?
the reason I think that it isn't a rod knock, is because it isn't steady.
kinda like
tap tap.....tap........tap........tap tap tap........tap.........tap
and only at low idle(750rpms)
what the heck could that be?
kinda like
1992 mx-3 GS-T, 10-12psi, T3/t4 hybrid, Turbosmart WG, AFPR, SSAC TURBO pipes, MSD Blaster coil, K&N, AEM W/B, MSnS(full standalone), 225Whp street tuned(10psi), 245Whp (12psi)(300bhp!!!)
1992 Fairlady Z(JDM RHD) 2+2 TT black(done!)700whp+
Don't Click Here! Trust me,Time waster!
- neutral
Re: oh oh.....funny knocking sound..
Could be timing belt idler/tension pulley making that kinda sound. Does it sound like it's coming from the timing cover area?
![Image](http://i116.photobucket.com/albums/o32/jimfyp/picnic4.jpg)
- mx3autozam
Just keep upping the boost on that k8 untill it goes away permanetly and there is no noise at all.
93 Mazda MX3 KLZE Turbo
HAHAH
yes...i like that.
If its a tapping i don't think it's a tensionner. Check your oil.
Make sure nothing is tapping on your hood (happened to me...)
Or anything is loose.
Also, can you hear it if you stick your ear in your exhaust pipe?
yes...i like that.
- PWRD_BY_HKS
wow pimp.... already.... you know the drill.... take off the manifold.... look at your valves.... what other symtoms... looping at idle, not starting up like it use to, not feeling as good as it use to, etc...
jdmx-3 KID OF THE ![Image](http://img118.imageshack.us/img118/8885/3kidkn5.jpg)
VICTORIA RACING
ZE PERFORMANCE IN 915 TX
Kl01-ZE,Kl31 ecu, millenia manifold, ngk plugs, ngk wires, probe tranny/ and clutch (stock), VortecH FMU 12:1, Aeromotive AFPR, Tial .38mm Wastegate w/ 4lbs spring, Walboro 255 pump, AiResearch T4, 3" down pipe, GODSPEED manifold, Spearco Boost Gauges, BF Goodrich G-force drag radials.
14.8 1/4 mile all motor untimed on boost.
VICTORIA RACING
- ElectricEnergy
I've never heard of that trick. Is that to see if its detonation? I don't think it would normally happen at idle.Also, can you hear it if you stick your ear in your exhaust pipe?
That intermittent tapping sounds like it might be a tensioner. My HLAs constantly tick.
![Image](http://i159.photobucket.com/albums/t148/electricenergy_album/caravatarcopy.jpg)
bleh swap for a de.
-hec
- solo_ryder
If it is getting louder everytime that you are driving the car and it dissapears at higher RPM then it probably is the timing belt tensioner... Post a vid of what is happening.
BTW - How's your wastegate holding up???
- se7en
wastegate? who needs that ![Razz :P](./images/smilies/icon_razz.gif)
nah, I have to let off at 4000rpms, cuz boost get over 5-7psi then.
kinda annoying, my wastegate is on backorder.
