Adj. fuel pressure regulator
94mxthree
Post by 94mxthree »
Would running one help the performance of the motor?.Would running a higher pressure help at all?.Need some feedback thanks.
RS_OBD'oh_2
Post by RS_OBD'oh_2 »
depends on your mods, if stock... no
94mxthree
Post by 94mxthree »
What if i got bigger fuel injectors with a different intake,would that justify adjusting the pressure?.
Limegreen mx-3
Post by Limegreen mx-3 »
NO if ur boosted thats a different story..
and if u put bigger injectors what management would u use to control them
because putting larger injectors on the stock ECU might make ur ECU go out of control.
and what do u mean by different intake
intake manifold
cold air intake (CAI)
there's a lot more to performance than just slapping it on research and search for what ur trying to do. I did and well im happy with what i got..
Like this u can't have all three
Cheap
FAST
Reliable
U can be Cheap and Fast but not Reliable
U can be FAST and Reliable but not Cheap
U can Reliable and Cheap but not Fast
U can't have all three
94mxthree
Post by 94mxthree »
Talking about a intake manifold,sheet metal type,asap going to buy one off a member here,but i was just wondering,if i went with a cai with the new intake manifold,adj fuel reg. and injecters would it make a difference?.
Limegreen mx-3
94mxthree wrote:Talking about a intake manifold,sheet metal type,asap going to buy one off a member here,but i was just wondering,if i went with a cai with the new intake manifold,adj fuel reg. and injecters would it make a difference?.
i guess u didn't read what i wrote
what size injectors and how would u control them
94mxthree
Post by 94mxthree »
No i read it,i was just posting what i had in mind,you asked what kind of intake,so i explained the rest of what was on the mind,but thanks for the input,lol least i know its a lost cause.
Limegreen mx-3
94mxthree wrote:No i read it,i was just posting what i had in mind,you asked what kind of intake,so i explained the rest of what was on the mind,but thanks for the input,lol least i know its a lost cause.
u might have explain ur intake but nothing on ur injectors
Joey's mx
Post by Joey's mx »
you wouldnt need crazy big injectors for the intake mani, CAI exhaust.....
I would say a set of BP injectors would be fine and to control them i would use a Apex-i SAFC!!! But you wouldnt really need injctors or management to run the intake becaue the stock injectors are not maxed out and the ECU is setuo to be running a little rich for engine safety anyways, so the intake CAI would compensate and make for a better ratio!!!
94mxthree
Post by 94mxthree »
Sounds good,just need to figure out what to do on my exhaust to open it up a lil bit.
RS_OBD'oh_2
do not mess with your fuel system unless you have some sort of forced induction. No, "ram air" does not count.
Joey's mx
Post by Joey's mx »
run a 2"-21/4" front to back with a hi-flow cat converter!!
94mxthree
Post by 94mxthree »
I'm thinking about 2 1/4 all the way,just don't know what muffler would sound the best,looking for a deep mellow tone,I'm not to big on the rice sound.
Limegreen mx-3
then u'll have to buy a decent muffler a cheap one will sound like RICE..
94mxthree
Post by 94mxthree »
Which mufflers on the market are decent?.That will look and sound good on a lil 4 banger?.
