Millenia alternator ?'s (I did a search so don't worry :) )
Okay so after searching, I found a good bit of info on the swap, but there are some ?'s I still have unanswered.
the first ? I have is since i'm doing this on the 4cyl, should I use the millenia brackets, and does anyone have any pics of it installed in ther 4-banger?
The second ? is what is the part # for the belts the millenia alternator uses, and at the risk of sounding like a newb, can the belts I currently have on my stock alt work with the millenia alt.
thanks alot everyone!
I dont see how anythign will work, brackets or belts, since they're designed for the K-series, which is completely different than anything else. You'll probably need to trial-and-error on the belts since the pulley, it's a different size, smaller or larger I dont remember.
What you guys may want to do is look/search on thread in regards to using a GS 90amp alternator, I know there are a few threds on this, one should be farily detailed if i remember right...it fits the same, just requires 1 extra wire hook up to ignition
I thought about that one as well, I just saw that there was a way to use the Millenia's amp, and thought (well hey more amps won't hurtNd4SpdSe wrote:I dont see how anythign will work, brackets or belts, since they're designed for the K-series, which is completely different than anything else. You'll probably need to trial-and-error on the belts since the pulley, it's a different size, smaller or larger I dont remember.
There is, just treat the millenia alternator as the GS alternator, the only difference is that there is 1 extra wire to hook up, and that's it.Dark_Rider2k3 wrote: I thought about that one as well, I just saw that there was a way to use the Millenia's amp, and thought (well hey more amps won't hurt)
- Josh
WTF ^^^^Nd4SpdSe wrote:I dont see how anythign will work, brackets or belts, since they're designed for the K-series, which is completely different than anything else. You'll probably need to trial-and-error on the belts since the pulley, it's a different size, smaller or larger I dont remember.
Yes it will fit onto a 4banger. only a 1.6 though(BP uses a v belt). you dont need to trial and error fitting belts or brackets, thats why your tension is adjustable. you use your stock bracket. the only differance is that the base mounting bolt goes threw the opposite direction, as the 60amp alt. Tunes is the one who knows about the wiring, and where you can get the plug to fit the alt.
aha! sweet!
I'll def. be using the Millenia alt, since i'll be doing the BP swap sometime in the future (Hopefully by the summer of 2008).
Also thanks for letting me know to use the stock bracket. (as I now see it hooks up like the GS). The wiring and getting the plug is ok, as I read his FAQ (nice faq btw).
Alright then! Thanks a lot guys, will hopefully get the alternator tomorrow or tuesday!
- Tunes67
One thing of note for the millenia alternator or any alternator.. the higher the amperage output of the alternator.. the more drag the alternator puts on the engine.. reducing the horsepower output of the engine. Just something to keep in mind when determining your goals for the car.
Tunes67
Tunes67
"So long.. and thanks for all the fish!" "Momma says VW Bugs are the devil" "This one time at band camp.. I stuck a flute in my Throttle Body" ![Wink ;)](./images/smilies/icon_wink.gif)
- Limegreen mx-3
won't fit a bp my azz im using a gs alt on my boosted bp..Josh wrote:WTF ^^^^Nd4SpdSe wrote:I dont see how anythign will work, brackets or belts, since they're designed for the K-series, which is completely different than anything else. You'll probably need to trial-and-error on the belts since the pulley, it's a different size, smaller or larger I dont remember.
u just have to swap out the UDP and water pump pulley for that of the 1.6 sohc or dohc, udp and water pump pulley and them u can use a gs alt on a BP..
You can't use the stock Millenia bracket.Josh wrote:WTF ^^^^Nd4SpdSe wrote:I dont see how anythign will work, brackets or belts, since they're designed for the K-series, which is completely different than anything else. You'll probably need to trial-and-error on the belts since the pulley, it's a different size, smaller or larger I dont remember.
You can't use the stock Millenia belt.
I didn't say you don't use the stock B-serie bracket, he was asking about the Millenia bracket. As for a belt, that's my mistake, but that's me making an assumption that it didn't have enough adjustment. I was assuming worse case senario...but if you can, great, if you can't, be warned, but that part, I dont know.
- Josh
Is that a small nose crank or a large?Limegreen mx-3 wrote: won't fit a bp my azz im using a gs alt on my boosted bp..
I looked everywhere and couldent find a serpintene crank pully that would fit mine. i found an aftermarket aluminum pully, but i didnt want to reduce the weight. i did just find a v belt pully from a 2nd gen that will fit the GS alt
really now?Tunes67 wrote:One thing of note for the millenia alternator or any alternator.. the higher the amperage output of the alternator.. the more drag the alternator puts on the engine.. reducing the horsepower output of the engine. Just something to keep in mind when determining your goals for the car.
Tunes67
Well what alternator would you recommend for the BP?
- Limegreen mx-3
large nose crank of couseJosh wrote:Is that a small nose crank or a large?Limegreen mx-3 wrote: won't fit a bp my azz im using a gs alt on my boosted bp..
small nose crank won't work at all.
the unorodotox (can't remember how to spell it) UDP for the mx-3 or stock 4cly mx-3 UDP and any water pump pulley from a 4cly mx-3 will work for the BP big nose crank.
josh ur sliping on me.. guy..
which do u have by the way..
- Limegreen mx-3
im using a gs alt on my BPDark_Rider2k3 wrote:really now?Tunes67 wrote:One thing of note for the millenia alternator or any alternator.. the higher the amperage output of the alternator.. the more drag the alternator puts on the engine.. reducing the horsepower output of the engine. Just something to keep in mind when determining your goals for the car.
Tunes67
remember there are two cranks that the BP use's
early BP's 89-91 maybe 92 use a small nose crank the 4 bolts that hold the udp to the crank have a rectangle shape pattern.
93 and up all use a big nose crank the 4 bolts that hold the UDP to the crank have a square shape pattern..
know u guys know if u didn't know i know some of u will say how can u tell.
u have a square shatpe pattern on ur crank u have a big nose and u can upgrade the BP alt.. have the small nose ur SOL
