Turbo rebuild question
hgallegos915
Post by hgallegos915 »
Ok this goes to all the turbo gods.
Ok I opened the turbo and heres what I found... the shaft is clean clean..no wear at all. The bearings are not scracthed and look new (turbo was in use for a week) The Dynamic oil (at the intake wheel housing )was leaking. The seal itself looks new.. how can this be??? Also the dynamic oil seal at the exhaust wheel was leaking.. it also looks new.. was it just cheap seals??
Im sending the assembly today off to ron(dude who I got the kit from)
for balancing.
It seems that the oil housing is a genuine garret housing, according to a local shop.
Basically what was wrong with this turbo was the seals...
Oh the rubber seal was half melted..
Did my seals go bad because of excessive oil pressure?
Any input would be greatly appreciated.
-hec
n2ogsze
Post by n2ogsze »
Was the turbo new or rebuilt?
T61 powered KLZE
hgallegos915
new. :/ i think it was a problem with my oil drain line.
turbo is freshly rebuilt, i just need the oil drain line made bigger.
-hec
Return to “Forced Induction”
