![Question :?:](./images/smilies/icon_question.gif)
[WTB] AfterMarket Cams
I was wondering if there are any aftermarket cams that i could put in my 1.6L DOHC. Miata cams? ![Question :?:](./images/smilies/icon_question.gif)
- neutral
They should fit just as well as if you installed a swap of 90-93 B6 stock Miata cams (which do fit the DOHC MX-3). In other words, they'll fit but you'd have to do something like swap position of the Miata/MX-3 exhaust and intake camshafts in reverse position. I can't remember the details, tried a search-of-all-terms for "miata cam swap" and apparently the UBB search function is still farked since a few days ago cuz I can't get a single hit on any search attempt, not even on the single keyword Miata. I have a set of MX-3 stageII cam regrinds so didn't have to deal with the Miata swap Q. Might want to try a UBB search later if you find the serach function has been fixed here...
![Image](http://i116.photobucket.com/albums/o32/jimfyp/picnic4.jpg)
