ford probe axles in an mx-3
A forum for discussions regarding the MX-3' transmission. Swap, technical, and troubleshooting info should be placed here.
se7en
Post by se7en »
I went to the wreckers and got the pedals, shifter and tranny mounts and axles and everything else I could unbolt from the car ;from a 93 probe gt(my Mx-3 is a 1992). will the axles work with my car? it was automatic before.
thanks
7
1992 mx-3 GS-T, 10-12psi, T3/t4 hybrid, Turbosmart WG, AFPR, SSAC TURBO pipes, MSD Blaster coil, K&N, AEM W/B, MSnS(full standalone), 225Whp street tuned(10psi), 245Whp (12psi)(300bhp!!!)
1992 Fairlady Z(JDM RHD) 2+2 TT black(done!)700whp+
Don't Click Here! Trust me,Time waster!
did you get the tranny off the probe GT also? or are you using an mx-3 manual tranny in your atx to mtx swap?
se7en
Post by se7en »
ya, I got the tranny from the probe also.
will the probe axels work? they seem to be a different part number, but the could be on the tranny side.
TREVO123
Post by TREVO123 »
Pretty sure the tranny is not going to work, i think bell housing bolts are diff.
Mnemonic
Post by Mnemonic »
the MTX from the ford probe gt will fit the v6 motor, as they are the exact same transmission. Though the axles from the probe will not work as they are longer
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
Raven95150
Post by Raven95150 »
From what I understand, the axle shafts are specific to the MX-3. Try http://www.car-part.com to find junkyards that may have them. I was lucky enough to find a GS MTX donor car at my local U-pull-it yard.
No more MX-3
2005 Hyundai Tiburon GT
95 F-150...6" lift, 35" tires
se7en
Post by se7en »
okay, here's my problem with those axles.
I pulled the axles from the probe, and also from my mx-3.
they look pretty close to the same length, but the probe ones have 28 spline on both ends and the mx-3 axles are 26 spline on both ends.
what do I do for axles??? the tranny has 28 spline and the mx-3 axles are 26 spline.
anyone run into this before?
7
edit: can I just mate the mx-3 outer joints to the probe inner joints?
do the insides match up?
Mnemonic
Post by Mnemonic »
you need a set of mtx axles for the mx3 gs
se7en
okay, I solved it
Post by se7en »
okay, I solved my problem.
here is the down low on what axles and intermediate shafts a person needs:
drivers side has to be from an mx-3 and has to be the mtx one.
passenger side:
(here is the problem I was having.)
the cv joint unbolts from the engine, and is quite long for a cv joint.
it can be separated at the bolt-bracket if you just hammer on it with a mallet or something like that(it doesn't look like it comes apart, but it does)
now, the tranny side is called the intermediate shaft, and it is the same for all kl series MTX trannys.(probe gt, 626, mx6, mx3, etc)
the outer shaft is the same for both mtx and atx mx-3's.(for sure, I double checked with new ones)
also, the reason that the probe, mx6,626,etc axles won't work is that the hub side of the axle has 28 splines instead of 26 like on the mx-3.
that is all you need.
7
I think that this should be amended to the "atx to mtx" FAQ I think. It sure would have been nice to have read it before I bought all those axles ;)
2fazed
Post by 2fazed »
I've tried Mx-6/probe alxes on the Mx-3. They look almost the same. But infact they are about two inches longer when there on. Thus, not leaving any room for the boot to move. Too tight.
Buy some from a place like Autozone, somewhere where there lifetime warranty. That will save you the time looking for used ones.
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
se7en
Post by se7en »
ya, they are longer, and also, the outer joint (on the hub) is 28 spline instead of 26 like the mx-3 axles.
fromtornashes
Post by fromtornashes »
where can you get upgraded axles
RIP Matt
Raven95150
fromtornashes wrote:where can you get upgraded axles
I don't know of any "upgraded" axles for MX-3s, but as was said above, just get them from a place like Autozone. They have a lifetime warranty so if you break them you get new ones for free.
No more MX-3
Raven95150
Re: okay, I solved it
I can verify that the passenger side shafts are indeed the same for ATX and MTX. The one I got from the junkyard with the MTX was clicking so today I put the one from the ATX back in and it fits perfect.
No more MX-3
ruthless_mx3
Post by ruthless_mx3 »
If you don't mind spending the money http://www.driveshaftshop.com sells upgraded ones and they are great with their warranty. I tore one up at the track and it was long past warranty and they repaired it for free. I had to have them make me a custom set to fit the jspec lsd trans.
good luck
93 MX3 GS SE KLZE -- RIP May 1, 2011
14.007 @ 98.46 1.991 60ft -- the only time she made it to the 1/4 :(
92 MX3 GS aka Goldmember - I'm trying to keep the legend going and as always credit to Andy for starting the legend ;)
sc61 currently @ 8 psi, wiseco 10:1 pistons, K1 rods, ported ze heads w/ kl31 cams
Return to “Transmissions”
