Thnx.
![Image](http://www.genelange.com/random_junk/CTS.jpg)
so when you did your swap why didn't you just swap the waternecks and have it functioning the way its supposed to?hgallegos915 wrote:LOL
ok the black one os the fan thermo sensor, the green one is the head temp sensor.. hope that clears things outalso the little one i guess its a temp sensor.
I dont have the fan sensor there.. well its there but not drilled. Just to erase the code. I have my fans manual to a switch.
Yes. 92-93 are the same, 94-95 are the same and 96+ were OBDII so different yet again. At least in north america.Are 94 and 95 models have the same setup?
