Is this FOR REAL??
- PatMX3
Is this FOR REAL??
This turbo is selling for $179.00 on ebay. Is this basically paying for what you get?. It looks real. Is it?. Click tha link*
http://cgi.ebay.com/ebaymotors/T3-T4-TU ... enameZWDVW
"93 Mazda MX-3 GS. Special Edition* 1.8L
Color -Rasberry Metallic. P-START Ignition*.
EuroLITE Dash Gauge* 77,000/m
#2nd Mx-3 Owner.
Mazda. Get in. Be M o v e d .
#2nd Mx-3 Owner.
- XxantwawnxX
Some people seem to have good luck with them.
I have one but i won't be running it on my car until i get a built 2.5 swapped in, even though the engine will be built i still won't go over maybe 10 lbs of boost . Otherwise it seems like a solid turbo.
Blaze Red '92 K8 Mx-3 GS. Never got around to a ZE swap. SOLD
1997 Eagle Talon TSi AWD. Don't worry i'll come back around to the Mazda world.
I took it to a shop and was adviced they do work.. however they are made of the cheapest materials you can find. The bearing isnt that good. it wont hold over 10 psi. I heard they do make power but well you get what you pay for.
-hec
- TREVO123
Try lookin for the Garret t3/t4 knock off turbo, it seems to work fine and can handle boost, and is decent quality, my bro runs on on his civic and has not had a problem with it, and hes at 11psi with it.
- Limegreen mx-3
tell you what guys when i was working at the shop
we bought one of these turbo's and
yeah
that turbo at 18psi was one one that made a 12.8@110 back in 12-06. I had it my mx-3 for a 1-2 months untill i replaced it with a 57 trim turbo.. which on that other turbo i made a 12.4@118.
so yeah that cheap turbo held up for about 2 months at 18 psi (remember not 24/7) and it was on a daily basis..
we just wanted to know if it was any good.. its ok but i didn't trust it and thats why i change it out..
some other guy got it from me and we its still alive. @15psi..
maybe that turbo was just lucky some how..
yeah
If it's coming from China, be careful, it may contain lead.
yeah be careful... I think the barbie jeep was turbocharged...MazdaManiacMx3 wrote:Mattel makes turbos ?Nd4SpdSe wrote:If it's coming from China, be careful, it may contain lead.
- PatMX3
Thanks guys all of your answers have left me with good vibes! i thinking about that saying, U GET WHAT YOU PAY FOR!. im gonna check out that knockoff of the garrett turbo* thanx PEEPS!!!!!
#2nd Mx-3 Owner.
#2nd Mx-3 Owner.
