y buy a 10 pound flywheel?
the on my ze came with weighs much less
stock flywheel vs. fidanza
The one on the ze is a FLEX plate.. automatic.. flywheel is forstandard.. you cant compare fidanza to stock.. it rocks to much.(fidanza)
-hec
I doubt that your ZE flywheel is lighter. The lightest stock flywheel is from the Mx-3 and it weights 16.5lbs, the stock Probe/Mx-6 flywheel is around 22-24lbs, which is probably the one that comes on an MTX ZE. If you got a curved-neck ZE, those come in automatic only, and as hgallegos915 described, that would be the auto flexplate, not a flywheel.
A fidenza is 9lbs, and if the lightest we can get for our V6's.
- mx3autozam
- XxantwawnxX
Re: stock flywheel vs. fidanza
Yea that was the flexplate man like they said. unless you got realllly luck and got a ze that was standard that some one EXTREMLY shaved the flywheel down : Pstudboy13 wrote:y buy a 10 pound flywheel?
Hehe, even then, Mx-3 flywheels shaved down to 11-12lbs are known for breaking...
- mx3autozam
because your not supposed to shave that much of a flywheel. You can shave about 0.005 to clean it up so it will mate with a new cluch nicely. but removing half an inch from the back to make it lighter is stupid. Then its unbalanced and can cause issues. I've seen unbalanced flywheels in Mustangs and its not nice believe me. It can cause deaths.Nd4SpdSe wrote:Hehe, even then, Mx-3 flywheels shaved down to 11-12lbs are known for breaking...
93 Mazda MX3 KLZE Turbo
