12.9 @ 114.97
A forum for Drag Strip/Track Racing Discussions. (NO Street Racing or Kill Stories, they WILL be deleted.)
hppwdn
12.9 @ 114.97
Post by hppwdn »
12.9 @ 114.97
~270whp for that run on street tires. Once I can get consistent 12s on street tires I'll try the slicks. Until then I'm not upping the boost.
For those that are interested the other lane was an 05+ modded GTO. I raced him three times. Awesome races every time. And the boosted KL whizzed by right about 1000ft each race.
Sorry for the lack of video. I never remember to bring the camera.
Here's a pic of the car.
bdr2k5
Post by bdr2k5 »
NICE, dang 115trap !!, i see ya doing mid 12 soon :lol:
93 mx-3 w/ Curved Neck klze
osargeant
Post by osargeant »
Great stuff, how much boost are you running on that KLZE MX3?
JSpec Turbo MX3 (1.6 DOHC)
http://www.cardomain.com/memberpage/310985
Port and Polished Head, Ported Intake Manifold, Valve Job, GTX Manifold, Hybrid Turbo, Cone Filter, 2.5" Exhaust, 2.5" Downpipe, ACT Street Clutch, Lightened Flywheel, MSD 6A Ignition, Boost Retard and SS Coil, Magnecor Plug Wires, Denso Iridium Plugs, UR Lightened Pulley, Spearco FMIC, Turbo XS BOV & MBC, BEGI RRFPR, Supra Injectors, Walbro 255 Fuel Pump, Autometer Gauges, Pivot Shift Light
Limegreen mx-3
Post by Limegreen mx-3 »
thats not bad at all about time there another 12 sec MX-3 out there..
i better start upgrading again or ur get a damn DYNO.
i so want to get into the 11's..
but great work u got going so any engine pic.
XxantwawnxX
Post by XxantwawnxX »
Awesome, gives me hope : )
hppwdn
Post by hppwdn »
That pass was 12psi on an 8.5:1 engine. I ran a 13.1@108 on 8psi with the boost controller turned off. The 12.9 pass is just getting started. It was my first trip to the track on 12psi, and my third trip since I put the car back together. This low compression motor on 12psi makes a little less power than my ZE did on 10psi, but it does seem to handle it much better.
The motor is Matt Maas' motor that he made 504whp on. It'll hold 30psi. I'm not upping the boost for a couple months. I'm bringing it up slowly until my driving skills get back in line. Been a long time since I raced on a regular basis.
Here's a pic of the engine with the red VCs. I have some silver vein ones I like a lot better. Yes, I know it's blurry. I'll get some good pics eventually.
The car will be at myrtle madness. Hopefully with a special surprise some people saw me walking around with last year.
mx3autozam
Post by mx3autozam »
thats a pretty sick setup you've got going on. I thought you had a custom intake manifold as well.
what size tires are you running..LOL btw looks great! get some video's
93 Mazda MX3 KLZE Turbo
mazdax3speed
Post by mazdax3speed »
what type of intercooler are u running, i love the way it sits
Orange 95' BPT GT28r, MSII on the way
hppwdn
Post by hppwdn »
mx3autozam wrote:thats a pretty sick setup you've got going on. I thought you had a custom intake manifold as well.
Yes, I have a custom IM, it's not on at the moment. Still needs some custom work with the fuel rails. I plan on having it on for Myrtle Madness in november.
Tires are 225/50/15s.
mazdax3speed wrote:what type of intercooler are u running, i love the way it sits
I got the intercooler from a guy that had a 2JZ swapped SC300 that went back to stock when he sold it. I believe the measurements are 15Hx24Wx3D. Something in that range.
Highbody
Post by Highbody »
nice numbers man... what psi do you plan on running this year?
323v6
Re: 12.9 @ 114.97
Post by 323v6 »
hppwdn what was ur 1/4mile time when u were all motor with 192whp?
rekognize
Re:
Post by rekognize »
mx3autozam wrote: Tires are 225/50/15s.
What kind of rims? offset? did you need to use spacers? I really like em
smallblockman69
Re: 12.9 @ 114.97
Post by smallblockman69 »
wow awesome mph... you need to work on your 60 foot... if you get that down that thing should be in the Mid 11's
mx3autozam
Re: 12.9 @ 114.97
Try to get that 60ft down to about 1.7sec....I think you will need to invest in slicks
hppwdn
Re: 12.9 @ 114.97
Post by hppwdn »
Wow, there's been quite a few replies since I last looked at this post.
323v6 wrote:hppwdn what was ur 1/4mile time when u were all motor with 192whp?
Never ran it like that. I lived too far from the track. I live closer now. I thought about making it all motor for a few weeks to see what it would do. The lack of power all motor would really help with traction.
rekognize wrote:What kind of rims? offset? did you need to use spacers? I really like em
Konig Minuz. 15"x6.5" +40 or +38 offset. No spacers. With the 6.5" rim I had just enough space to fit the 225/50/15s under the strut perch. Had it been a 7" rim I woulda been outta luck.
smallblockman69 wrote:wow awesome mph... you need to work on your 60 foot... if you get that down that thing should be in the Mid 11's
I usually get 2.1/2.2 on street tires. In my old probe I got consistent 2.0s. In a fwd car it's pretty hard to do better than a 2.0 on street tires. Plus trapping 115 I was spinning most of second and some of third. 115 is mid 11s in a car with traction, but a fwd turbo car doesn't get the type of traction it takes to run mid 11s with a trap that low. At least not on street tires.
mx3autozam wrote:Try to get that 60ft down to about 1.7sec....I think you will need to invest in slicks
I have slicks, I just never use them. I have a lot of goals I want to get with street tires. Plus I've already been towed home from the track once from breaking an axle. I'm kinda weary to bring my slicks out there and risk breaking the tranmission.
Return to “Drag Strip/Track Racing”
