sephia trans
A forum for discussions regarding the MX-3' transmission. Swap, technical, and troubleshooting info should be placed here.
nobodyhere671
sephia trans
Post by nobodyhere671 »
what years of the kia sephia trans work with the bp, i know the 95-97 ones work, but will the 98-02 transmissions work too?
Limegreen mx-3
Post by Limegreen mx-3 »
no different bell housing patterns.. the 98-02 models.. i know i tried about a year ago..
jaydog5678
Post by jaydog5678 »
Too bad to because the newer versions look even stronger than the 95-97.. :x
Yoda
Post by Yoda »
That because Kia started to switch over to Hyandai engines and trannies when Mazda sold the holding and involvement in Kia in 97-98'
Limegreen mx-3
http://www.mx-3.com/phpbb2/viewtopic.php?t=54754
I did swap over bell housing when i had a transmission from a 2000 kia sephia
2000 kia trans
mazda g-series bell housing
and a set of gears from the mazda the side where the clutch slips in..
reason why is that the kia gears where to tall the shaft and the mazda gears shaft was short and all screw this..
to do what i did about a year ago is to much work and i never bolted it on to see if it was any better.. my boss throw it away months ago..
i was a 2000 kia/mazda hydrid trans that i think is not worth the effort to much bs it get it to work and not worth the time and money..
Return to “Transmissions”
