CAI question...
- umcamara
CAI question...
I've been reading basically everything on this forum for the past few months and have just recently created a username and started posting a little. I have done tons of research on my car and spent countless days reading posts and working on the car.
I'm interested in purchasing a written-off car with the BP engine (escort, protege, sephia, whatever...) when I can find the right one.
My question is this. I have a '96 MX-3, obviously with the 1.6 dual-overhead, and would like to purchase the Weapon-R CAI. I'm wondering if when and if I do get the BP, the Weapon-R will be compatible.
I've looked at the part #'s for the CAI's for the escort, protege's and mx-3's, and they're all different, but I'm wondering if that's just because of the dimensions of the engine bay, and not the engine itself. I know the 1.6-DE has 3 hoses connected to the air intake (egr solenoid hose, not entirely sure what the other 2 are). I wonder if these are the same on a new gen BP. Maybe the throttle body inlet diameter is also different.
Thanks. Great site.
Thanks. Great site.
PoisonDrop
I'm pretty sure that intake would work. I used the same intake from my 1.6 on my BP, but I used to have the SOHC. The DOHC throttle body seems to be the same as the SOHC (don't quote me on that, I don't know for sure), so I don't think you'll have any problems...
93 MX-3 BP - Worklog
justin22_22
weapon r/secret weapon intakes are short ram intakes
technicaly...all you have to do is put a filter on the tb to get a a ram air affect (or at least the one they speak of these days)
if your wanting to get a good intake thats short and simple you might as well get a few hood scoops and just run your intake through the hood and get a true ram air effect... other wise..just go to your local muffler shop and tell them the demensions of what you want and pay about 50$ for your own CUSTOM intake :nods:
all in all your going to be waisting your money if you buy it from a retail company.
1994 MX-3 1.6L B6DE 16v DOHC - rear disc swap, nix power steering/ac, Corksport f&r strut tower bars, Pedders urethane control arm bushings, urethane motor mounts, steel braided brake lines, painted dash, protege tranny
90 Miata w/ b6, Konig Lightspeed rims, Cams (boost to come soon)
74 Porsche 914 w/ 1.8L - restoration prooject
thats not true
the cone filter allows for better all around flow plus the flex pipe used in todays systems restricts the flow
a solid one piece pipe with as few bends as possible will allow for better breatheablilty
Put it on a dyno. See for yourself. You are dealing with 1/4's and 1/8's of Horses.
A stock Crinkle rubber hose vs. a shiny piece of aluminum.
The same goes for ppl who believe that hollowing out/removing a cat will gain them power over having a good non-clogged cat inline.
This is dealing with street cars here. Not drag cars
Drew
'95 EGT 1.8 T
'93 ELX 1.9 SC
'91 ELX 1.9
'95 EGT 1.8 T
'93 ELX 1.9 SC
'91 ELX 1.9
ModMX3 - (Carmaster2005)
True , an aftermarket intake might not do much on a otherwise STOCK 1.6 . The key Ive figured out with thease small engines is have parts that work together, Say rather then just a cai, you have a cai, headers & a full exhaust, and a set of performance cams, Now that little 1.6 can breath and you may see over 15hp rather then 2 or 3 with just a cai. Also one thing to consider is to ditch the cai and just get a BPT 1.8l turbo. If your going to do an engine swap, that would make the most since as you can buy the bpt all together and drop it in for a little more then the bp. Youll save a lot of time and effort in the future. also about 50 more hp then the basic bp.
