Engine running rich
V6Gav
Engine running rich
Post by V6Gav »
recently bought the car which had been sitting for 6 months, got it running after re charging the battery and changing the plugs, but it is running very very rich and stalls whn u rev the engine high and take your foot off the accelerator pedal, i think its flooding itself. Any ideas how 2 fix this??
£125 V6, be on the road sooooooooon!
m90daytona
Post by m90daytona »
could be the fpr leaking or a fuel injector stuck open. or a maf sensor reading to much air or a bad pcm or a bad tps sensor. could be a lot of things. is the cel on?
PATDIESEL
Post by PATDIESEL »
No CEL on E-spec MXs. Have the fuel injectors checked. I'd bet one if gummed up and stuck open. You could try some fuel system treatment, but I dount it cures the problem.
mrmike420
Post by mrmike420 »
I'm having the same problem with my car... I'm thinking it might be linked to a vacuum hose. I will soon be replacing and re-routing my hoses as well as installing a newer engine wiring harness. I hope that does the trick. :)
~FUeGo~
92 MX-3 GS, 5spd, Black Metallic, Tokico ZX2 Struts, Eibach Springs, Sylvania Silverstar Ultra's, K&N A/F, Suzuka S/S Brake Lines, KGS Dual Tip Muffler, Dynamat Extreme Trunk Kit
MX3ak
Post by MX3ak »
Sounds like my EGR problem.
Jump TEN and GND plus a LED between B+ and FEN
If it's code 16, Bingo. Just unplug EGR and go out for a spin...
K8 running LPG (Liquified Petrol Gas)
mrmike420
Post by mrmike420 »
I'll try that, but I was told my EGR was fine when I had my engine replaced.
~FUeGo~
