good waste gates
- PWRD_BY_HKS
good waste gates
Okay so I was told to that tial 38mm is a superior wastegate but its like 250 dollars you know. So is there any other less expensive brands I can use. Remember I will only boost 4 lbs. No more. Never.
jdmx-3 KID OF THE
VICTORIA RACING
ZE PERFORMANCE IN 915 TX
Kl01-ZE,Kl31 ecu, millenia manifold, ngk plugs, ngk wires, probe tranny/ and clutch (stock), VortecH FMU 12:1, Aeromotive AFPR, Tial .38mm Wastegate w/ 4lbs spring, Walboro 255 pump, AiResearch T4, 3" down pipe, GODSPEED manifold, Spearco Boost Gauges, BF Goodrich G-force drag radials.
14.8 1/4 mile all motor untimed on boost.
VICTORIA RACING
- Limegreen mx-3
turbo concept make a knock off tial that works dame good. its a lil cheaper under $200.
- PWRD_BY_HKS
Thanks and it works great too you said right
jdmx-3 KID OF THE
VICTORIA RACING
VICTORIA RACING
Tial
sard
sard
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
Man you need to make one big thread not 1000 little ones, and instead of asking a million questions , go read Maximum boost by Corky bell .
Great book very informative , also if you want cheap parts , Buy used , Go to ebay. Also you can use some generic parts for only 4lbs of boost , not everything has to be top of the line for a budget kit like that ..
Not trying to target you and flame you , just trying to inform you on some stuff
Kris -
Kris -
93 Kandy Tangerine Mx3 GS-DE
02 Subaru Impreza OBS
& Lots of Toys to haul
ive heard things of the teal knocks offs at low psi. Thats what Ill be using at first. I got me a 4psi yellow spring. Inspected the plunger at it all seems sturdy. Also out wastegates dont sit right on the head like most other kits do so it wont get as hot as those. Some header wrap of course will help. I tought you already had a good waste gate?
-hec
