mercury capri 1.6L DOHC head work on B6SOHC block (mx3?)
bradsescort
Post by bradsescort »
I was curious if this will work on your blocks. I have heard that you may have to port out some passages and others have told me there is no difference between the b6dohc and b6sohc blocks, same with hte b8sohc and b8dohc blocks.
if the same check it out if you need one.. thanks
http://www.clubprotege.com/forum/showthread.php?t=31792
pm me
bradsescort
btw i forgot to mention this is the same identical head, camgrind, valve cover, intake manifold design (equal length intake over vc) as the 323gt (non-turbo)
