Hello
Could someone know where to connect the single wire Coolant Sensor near firewall?
I was getting code error no.9 so I look around and found the connector unplugged in the rear of the engine.
Coolant sensor ECU connector
K8 running LPG (Liquified Petrol Gas)
- 94mx3precidia
reset your ECU and see if it comes back. To reset your ECU just disconnect your batery and leave it for a half hour then press on the brake for a few seconds to ensure that all remaining voltage in the computer is disipated. hook your batery back up and take it for a test drive.
1994 MX-3 GS KLZE, Probinator, Bully stage 1 (probe GT), B&M Short Shifter, 2 1/4" Custom headders back.
- PATDIESEL
The real way to clear the ECU is to unplug the neg. side of the battery, step on the brake for 10 seconds, plug the battery back up and crank to see if you still have a cel. No need to wait 30 minutes.
