new age bp in an mx3?
im not sure of the year but its a black newer body still riht after the 94's body style with the funny looking taillights..its a bp and im getting the motor trans, ecu, harness, axles and mounts for 350 so yeah....wil that work?
- Limegreen mx-3
its its a 95 protege wiring harness and ecu won't work.
huh? so can i use this motor? what all do i need cuz im getting everything off the car that i need, wich ecu do i have to use? the b6me? the protege its coming out of is this exact model and color too actually heh.
http://www.carsct.com/pics/1269A6.jpg
- Limegreen mx-3
BP, trans, axles yes.
ecu, wiring harness no its obd II. ur mx-3 is still obd I and to much trouble to convert to obd II trust me.
u'll need to the wiring harness ecu from a 92-93 protege the box model and probly the intake manifold and exhuast header. that newer BP has a different intake manifold and the wiring harness will not plug up to that one.
- atlantamx3
- Limegreen mx-3
Ft2 u ain't got the cash to make it fit FE3 same there.
Ur better of finding a 92-94 mazda protege LX/GT.
just do it the right way u'll be better of in the long run.
don't take our word for it do it the hard way.
if you have a sohc dont get the new gen, im pretty sure the new gen bp 95+ are obdII. the new gen looks just like the mx-3's dohc b6. just get a 90-94 bp from a protege and shouldnt be too hard. if you go new gen your gonna have to convert to obdII and its just a hassle.
he wants you to do it the hard way so you'll learn from it. just that simple get a 93 or a 94 bp. no need for a new gen. good luck
Jon
Jon
1995 mazda Mx-3 RS 1.6liter DOHC B6-DE
thanks bumpy, i need my car to getb ack and forth to work but i need a new tranny so i think im gunna hold off for a while on the bp swap and just get my new tranny an have it installed cuz i dont have the time for it unfortunately. i know i can use a bp's tranny but will it all just bolt up just the tranny and mount and friction plate?
- Limegreen mx-3
there more work to be done to get a BP tranny on a 1.6 sohc. i know i have done it to the blue mx-3 that has the sohc im waiting to boost.
