oil in spark plugs
oil in spark plugs
hey guys i went to change my spark plugs and wires and when i removed the back ones 2 out of the 3 had oil all over them what does that mean, i know its not good but what causes that does anyone know?
- mitmaks
Im sure when you removed your spark plugs oil that was on top of them just poured down and coated rest of the spark plug. You just need to replace gasket.fritzfab wrote:no the oil was all over the spark plugs they were covered from top to bottom and dripping when i pulled them out , and it could possibly be a really bad leak and my car definately lost power from it i can tell so im really concerned what do you suggest
If you run it for a while the oil should burn off and the engine should be fine, shouldnt be any loss of power with a leaky rocker gasket. If the leaks that bad then id replace the rocker gasket, the front of mine needs replacing and its and easy job, think the back will be a bit harder but shouldn't be a big job.
£125 V6, be on the road sooooooooon!
