Thanks for the comments guys! I am DYING to tune the car. The injectors are the only thing I need to start tuning for big power. The ones I have now are just the stock gtx injectors. Ahh 94% duty cycle.. I am thinking of going for 20 psi on this turbo which should be.. well.. insane. Im just hoping that I will be able to get there on 91 octane. I'm going to go as high as I can on pump gas. I'm not getting into mixing gas or anything. I envy you guys who can get 93 octane and higher.
Im going to shoot alot of dyno footage and driving footage once I tune it. So look foward to that.
Dynoed the car..
- Limegreen mx-3
just 20 psi try 25psi thats what im going for on the dyno soon. im already at 18-20 psi depending on my mood. 93 oct. gotta love TX we got it.
- papa roached
havnt really posted on here in a while, good to see that your going to be making some big power here soon franko, wish i was
