SoloII/AutoX June 17th. VMSC @ RIR (Pics & Vids)
First autocross event of the year. Great time. Took part in the VMSC event down here in Richmond, VA in the Richmond International Raceway lot.
Vids:
http://video.google.com/videoplay?docid ... 7672620004
http://video.google.com/videoplay?docid ... 8321506703
Pics:
- XxantwawnxX
awsome!
sweet action!
Didn't do too bad, just went out and had a good time, giving some friends some rides, making some local aquiantances. My best run was a 57.1. Most were averaging around 54. The way it was ran, there wasn't all that much time between runs, I could of tweaked the tire pressure to get oversteer but I didn't care, just having a good time. Probably next time, was my first time out with my new suspension anyways.
