93_4banger- 93 Mazda MX-3 BP-Turbo
93_4Banger
Post by 93_4Banger »
well i got the bp in but waiting on my G-series tranny and then everything should be good installed the intercooler. Pics will be taken if it ever stops raining were on 5 days straight and my work is solely done in my driveway due to lack of garage.
Plans After Swap and Turbo Tuned:
Taking out back seat going to carpet all the way up to the front seats. I have plans to get my hands on some racing seats .so i am going to build a roll bar with hooks to attach the harnesses too. Let me know what yer ideas are on that set-up
Last edited by 93_4Banger on September 18th, 2006, 3:08 am, edited 1 time in total.
93_4Banger
well i finally decided to get an engine management system while i await the arrival of my new transmission.
I got a Megasquirt Unit V 2.2.
also i have made a deal with a guy locally to get two new ractive seats and harnesses.
Vanished
Post by Vanished »
lookin good man! gimme a ride when its done sometime, and then help me with my KLZE
1992 Blaze MX-3 GS *R.I.P.*
1993 Blue 93 SE-ZE
http://www.cardomain.com/ride/2770987/2
93_4Banger
Just showing you the BP installed and the intercooler installed the bumper is not back on yet because i still have to run piping.
93_4Banger
UPDATE!!
Just pulled the motor to install my G-Series Tranny and New ACT Stage 3 Clutch and resurfaced flywheel now its just down to wiring it all back up and bolting everything back together before its running and turbocharged.
TREVO123
Post by TREVO123 »
Thats looking good dude!! Waitin for your stock engine and tranz to arrive still.. Hope its quick.
Vanished
Post by Vanished »
Hows it commin? Any updates?
1993 Blue 93 SE-ZE
93_4Banger
The only update is that i received the new to me tranny which will be installed sometime in the next two weeks and i bought new muffler Dynomax Super Turbo, and also a SS TIP. Im waiting on a few parts from Limegreen and then itll be running on little to no boost because im still trying to search for a tec II.
Ill Get pics up Soon
93_4Banger
well after many delays she is running... but the seats arent intsalled yet and im still wiring up the safc and wideband ill include some pics of the new parts.
Also the first pics are of the valve cover i refinished old to new.
OLD VC
Refinshed By Myself
Then the SAFC, FPR and Wideband
Vanished
Post by Vanished »
AWESOME
freakin a. Killer job on the valve cover man, looks MINT. I'm impressed. So, whens it gonna be running? Did you get some rails done up yet?
1993 Blue 93 SE-ZE
93_4Banger
MINOR UPDATE!!!!
Just recieved the Boost Controller in the Mail...SOOON to Run 15psi.
Also ive began fabbing some seat brackets. Got the Mounting holes drilled just need the flat bar to attach to the seat.
cstott282
Post by cstott282 »
nice progress...
93_4Banger
well its been a long road, and im am soo close, i got the new throttle cable installed as well as the a-pillar gauges and wideband and SAFC wired up. Got the batter relocated to the trunk and the power steering out as well as the intercooler piping fitting perfect all i need is a lower tranny bolt so the fluid doesnt come out and to install the new 255 fuel pump.And anew tps. Shud be initial start up tnext week.
93_4Banger
got the wahlbro 255 in today with a little fuss from seized and stripped bolts, also went to the dealer for the tranny bolt. The safc turned on without the ignition just with the battery hook up soo i have it hooked up to the wrong power source. ill try to figure that on my days off on the weekend. Im very close only need the tps and tranny fill.
