How is your Coasting
Slickjr09
Post by Slickjr09 »
My coasting seems very weird, i give it gas and its at rpm's like its at 3500-4000 and as soon as i let go off the gas it drops around 1000 and a little lower, is this normal, i feel it lose all this power when i let it go and then it doesnt coasting? how about youguys
1992 Automatic Mazda MX-3 GS
94mx3precidia
Post by 94mx3precidia »
are your breaks dragging?
Boris
Post by Boris »
i think ur referring to overdrive.
1993 1.6L SOHC. Mazdaspeed mounts, BP09 ECU, BP VAF, Fidanza miata flywheel, exedy miata pressure plate, centerforce mx3 disc, tokico struts, B&G lowering springs, and some sh***y motomaster tires.
Slickjr09
Post by Slickjr09 »
I just had my brakes changed today, and its still doing it, i dont know if it still draging but i would guess not becuse they were just changed
94mx3precidia
did the i guess anti-coasting occur when your breaks were changed or did it do it before the breaks were changed?
Slickjr09
Post by Slickjr09 »
do you thinks the overdrive botton is on you mean, beacue i bought the car a mounth ago, its always been doing it but the overdrive button is broken off, right next to the shifter, could it be on and doing this you think???
Slickjr09
Post by Slickjr09 »
both befor and today too
94mx3precidia
well if the button broke off while the overdrive was on then its on. try seeing if u can click the button off.
Slickjr09
Post by Slickjr09 »
gonna get a flash light and look now
94mx3precidia
im not that familiar with the overdrive though, i just got my mx-3 like a month ago and i havent used the overdrive yet
94mx3precidia
if you can, take a picture it would help out a lot.
Slickjr09
Post by Slickjr09 »
Ok i went to take a picture but my batt died so its charguing i willtry again in 10 min, but it seemed like it was swicthed up so i swicthed it towards the back off the car, i got acited because it looked like it was on and i turned it off i drove it around the block and same thing as befor, but i dont know if i turned it off or on, it seemed like i tured it off because i pused it back but i dunno
Slickjr09
Post by Slickjr09 »
Another thing in consideration, when i hit my brake to bring it out off park and in to Drive I hear i click noise from around the shifter, and i was was taking these pictures i noticed that it is the overdrivr clicking , jumping up and down in there when i brake,,,, any clue hope the pics help
94mx3precidia
when i get home tonigh, ill have a look at my overdrive button and see which was is on and which way is off.
Slickjr09
Post by Slickjr09 »
ok thanks, and what do you think of the clicking noise??
