MOT FAIL - Emissions
A place for the MX-3 Community in Europe to gather.
Reborn
Post by Reborn »
Just had about £900 work done on my car to get her back on the road again after taking it of for 6months.
Suspension, Braked, Oil/Fuel filters, New Clutch (MX-6) and other things.
But its failed the MOT on its emissions, 2nd Fast Idle, I have a Custom exhaust which isn't especially mad, its just a twin 3.5"
I'm concerned i have a dodgy 02 sensor or perhaps something worse....has anyone got any experience in getting a car through its MOT with this kind of problem
The Artist Fromerly Know as UKMX-3
MX3ak
Post by MX3ak »
V6, right?
If the problem is Idle, you can adjust to specification (650rpm) by puting in diag mode plus adjust screw on throtel body.
If the problem is variable idle (up, down) the you got a leack in vaccum system. Check every air hose aroud intake manifold.
If the problem is emissions, check catalytic converter.
But maybe to much oil burning too. then only solution is new head gaskets or/and valve steams.
Best luck!
K8 running LPG (Liquified Petrol Gas)
Reborn
Post by Reborn »
Not that, apparently its needing two new Lambda sensors also known as 0xygen Sensors for the exhaust..........that explains why she's been running rich recently.
So thats £153 per sensor...ouch!
capamx3
Post by capamx3 »
Are you sure that the sensors are bad, not only just an error in the diagnostic box?
Master of big-bored throttlebody!
Mods:
Venom VCN-1000 NOS, custom lightened flywheel, 6pads race-clutch, custom big-bored-tb, modded fuel-pressure, race-header, 100cpi catalytic converter, 2 1/2" midpipe, short-shifter, 60/45mm KAW/Kayaba Suspension/Shock-Kit, Zimmerman Drilled Brake Disk, Stainless Steel Brake & Clutch Line, Exhaust Fogging System, Custom Made Alpha-N-Controlling, Apexi RSM, Water-Alcohol-Injection, 2 Lambda-Meter,
Reborn
Post by Reborn »
The garage is pretty sure its the sensors yeah.....
Sounds about right its had all the symptons, hesitation under acceleration etc.
MX3ak
Post by MX3ak »
If it´s the Lambdas error on the Diag, then yeah, better replace those. Then reset ECU.
You can get them both for less than 50$ on ebay. Universal Mazda 4 wires.
Reborn
Post by Reborn »
Thanks for the assistance!!! :D
Return to “European MX-3 Community”
