315,000km and still counting
- Princess*Precidia
I was planning on doing that, paint jobs here are kinda pricey unless i do it myself...and finally get a body kit on it this summer, i cant stand that color, the car itself is in good shape, the engine could use a little work tho, plus the milage on it is pretty high too...its got over 200,000 miles on it...pretty high for an mx-3 but she still runs
- Princess*Precidia
- wyldside
Well for simplicity sake, I'd say to look for a new MX-3 with the 4cyl DOHC engine ('94 - '96 RS). Go with Manual Transmission if you can. If the engine is good in the new one; then great! If not, just swap in your old engine from the DOHC (without the transmission). Should be a straight swap without any problems. If you come to some of our events, we can probably give you some good one on one, in person advice. I've assisted an ex-member (Justin Ollerich) in converting his SOHC to a DOHC engine. Let's just say it wasn't pretty, but it worked out in the end.
Once I get my rebuilt KLZE installed again, I will have over 300000km and a new powerful engine with just over 200HP.
James Gosteli
X-Prez of MX-West
1992 Seal-Gray MX-3 GSR-ZE (KLZE 2.5L V6)
1992 White MX-3 GSR-ZE (KLZE 2.5L V6) Worklog (Parting out)
1993 Blaze Red MX-3 GS - RIP
X-Prez of MX-West
- Princess*Precidia
- wyldside
Well, there's the X-Series meet on the 26th. Maybe we'll see you there.
James Gosteli
X-Prez of MX-West
X-Prez of MX-West
- Princess*Precidia
