Megasquirt question
nos92mx3
Megasquirt question
Post by nos92mx3 »
Wondering what wire you guys tapped into for the ignition switch.
I have still yet to wire that or the fuel pump and was also wondering if i could let the stock computer handle all of that?
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
babyblueMX3
Post by babyblueMX3 »
I'm guessing this question is for your rs-t (4 cyl application) ?
RIP 400whp ZE-T MX-3
nos92mx3
Post by nos92mx3 »
yes that would be correct.
93' Rs-t BPT - Sold
m90daytona
Re: Megasquirt question
Post by m90daytona »
nos92mx3 wrote:Wondering what wire you guys tapped into for the ignition switch.
remember that whichever one you tap in to has to have power DURING CRANKING. use a test light to figure it out. also, i dont believ you can use the stock ecu to run the fuel pump because it turns the pump on when it sees crank signal and since ms is going to be stealing your crank signal the fuel pump will never turn on.
