Hi people,
I hope this is the correct place to ask?
Basically i've owned a Red 1992 MX3 V6 for around 2 years now and as you can imagine it's starting to look a bit tatty and old. Now it's getting a blowover in a few weeks because it is more pink than red now and getting the wheels refurbed at the same time.
I was also thinking about trying to make the interior a bit more modern too and would like to change the heater control panel to the newer style.
I have the old slider control but i would really like the newer button version.
I can easily get the part cheap on ebay but before i do i'd like to ask how difficult the job is? Can it be done without too much fiddling with wires? Or is it just not worth the hassle?
I'd also like to replace the horrible plastic steering wheel for the newer spec ones. I know i won't be able to use the airbag but mine doesn't have one anyway and i think the newer ones look alot nicer Again, is this and easy swop job or is there more to it?
Thanks for any help.
Replacing old style heater control panel for new.
well if I remember correctly from my 94 dash that the new heater controls do look much nicer with buttons instead of slides... but if I'm not mistaken it is all wires instead of cables. Somebody correct me if I'm wrong... it's been a few years since I took mine apart.
Also why don't you just upgrade by putting the white indiglo hvac overlay on? It is pretty inexpensive and IMO it makes it look really nice especially if you get some white speedo gauges to go with it!
good luck with whatever you decide!
old dash works with a sliding pin and a wheel to change for example the blower ( 0,1,2,3)
new is completely electronic, so it won't work..
2.5L KLZE engine, CF hood, Postert frontbumper, kmax skirts, custom diffusor..
MY RIDE:
http://www.mazdamx-3.nl/members/member_show.php?id=102
MY RIDE:
