possible clutch prob???
when i depress the clutch i get a screeching noise from the engine and engine rpms drop sometimes to a stall, the car also vibrates when pulling away. this just happened suddenly. i only took the car out for a spin and while driving at 60mph smoke cae from the engine bay along with a burning smell. i think it the clutch thats f**ked when clutch is depressed now the car struggles to go into gear. the only thing i did before this happened was take off the inlet manifold and replace gaskets. does anyone know what this could be? thanks
- ryan_Fuerte
most part stores will carry an oem clutch, for a little more grip, go with a clutch from a probe or mx6, they have a larger surface contact area. I believe there the same as the 94 + mx3's. The 93 and lower use a smaller contact area.
stock clutch is around 125.
_Ryan
_Ryan
Mx-3 GSr : Rebuilt klde with 5spd swap, xtd stage 3 clutch, Magnaflow dual exhaust,Accord custom intake, kyb gr2 struts with eibach springs, civic dual halo projectors, black altezzas, white 15'' oz rims, rolling on dunlop street slicks.
http://www.cardomain.com/ride/2400330
