Transmission help needed!
I am new to mx-3.com and also new to the mx-3. I was given a 94 mx-3 1.6L DOHC from my sister because its transmission has gone out (wont shift properly and you cant go over 25mph). It is an automatic and it was just a reason for me to convert it to a manual. If anyone could, I need a list of possible donor vehicles with similar transmissions. I have been able to find 5-speeds for the V6 although that doesnt help me much considering I have a 4 cyl. If you could let me know, years, makes, and models of vehicles with the transmission i could use, that would be great! thanks!
Napalm7629
- TREVO123
94 or 95 the trans should work 96 has a diff tranz.
I don't know about the 626/Probe/Mx-6 4cyl trannies being compatible. I dont know much about them, but are a totally different type of motor, no matter the generation, so I assume they use a totally different trans.
If you had a V6 Mx-3, the V6 626/Probe/Mx-6 would be (specifically the manual transmissions), reason why we can easilly swap out the motor and/or the trans. Your probably mixing up the 2.
- papa roached
the only trans that are straight bolt up are 4 cyl MX-3 transmissions or 323 transmissions, you can swap in the BP tranny out of a protege but theres a bit more work involved ans is not a straight bolt up
- 94blaze1.6
Yes early 90's 323 have the same series transmissions... The tranny itself should bolt up to the engine you have but you still might have to look for the 3 pedal assemply out of an mx3 because I dont know if they are the same.
95 RS so far just a paintjob, rims suspension next then turbo...
I have turbo dreams and detanation nightmares
